Feed hold/Pause job question
Is Feed hold and Pause job the same thing?
Can not find shortcut for Feed hold. If its not the same thing, were is the shortcut key for Feed hold?
/Jon
@jonnorberg What version of gSender are you running? I can’t find any UI or button for “feed hold”.
In other senders there is a Feed hold, but not in Gsender. But is the Pause job doing the same thing? Stopping movement with the option to resume?
I see the expression of feed hold is widely used, so is Pause job the same thing?
I’m on 1.4.11.
@jonnorberg I misunderstood your question. There is no shortcut for Feed Hold because, as you have seen, there is no Feed Hold command.
Pause job does stop movement with the option to resume. When you pause, you will see a resume button appear.
So it is the same thing with two different descriptions. Nice, then I know. Thank you!
We generally try to use more user-friendly language. Feed hold (and cycle start) is a bit more technical and obtuse for the average user than pause/start.
