Fusion multi-tool file issues
Hi everyone,
I’m now working on getting multi-tool .nc exports to work in Fusion, and running into an issue - gsender will happily load/run files that are “split by tool” in the standard grbl/Grbl post-processor, but as soon as I change the setting to “no splitting” gsender can’t open the resulting files at all-- it doesn’t hang or crash or anything - it just does nothing after i ask it to open them – whatever file was previously open remains open!!
Any thoughts?
Cheers,
Jon
update: it turned out gsender needed to be restarted and then it worked fine – one specific sub-file was the issue and wouldn’t load prior to the restart – once it loaded, the joint file also worked fine – is there a more stable iteration of gsender?
@photonjon What version of gSender are you running? The latest is 1.4.9
1.4.9! I’m up to date, gwilki-dude :slight_smile:
j
@photonjon You may want to open a support ticket with Sienci for this question.
