Good afternoon everyone. I am wondering if the touch plate on the MK2 can be used to zero out the x,y,z axis’s with a 60 degree V bit.
Thanks for the help.
@EricMac - First off welcome to the forum Eric. Plenty of help here. Yes the newer autozero touch plate can work with Vbits as well as others. The older/original not so good for that. Lots of users will zero XY with a 1/4 inch straight bit then change to the V bit and zero Z seperatly either manually or using the Z tab on the autozero touch plate. Hope this helps.
Thank you very much I will give that a shot.
