G sender or Vetric Glitch
I have a small Tic Tac Toe project. 7.375x7.375x1.125
Used prob to set xyz start. It did its job and moved to the bottom left corner just like normal including the z. When I start it x and y are ok but z is air cutting 2" plus over the project.Checked my project thickness and settings for the 60 deg. v bit Ii am using and all is as it should be. Rechecked everything. closed G sender and turned off the longboard. Restarted and did the probe again. Same result. Any help in understanding why this is happening would be appreciated.
In Vetric, make sure you are setting your Z Zero Position to the “Material Surface” not “Machine Bed”.
Yep that was what was wrong! Thanks!!!
@Rstd2005 As @jmckeand resolved your issue, I am closing the topic.
