I have been using g sender since introduced. Today it is not seeing the Z probe after doing an update, suggestions appreciated.
I have reset to defaults, restarted the computer, still does not see the probe when I lift up the pad and touch the bit. Very frustrating, hate doing updates, messing with my workflow to say the least…
@Bill I would check the wiring. Make sure that the wires in the probe are tight and secure, make sure the wire in the magnet is tight and secure. Finally, make sure that the wires in the green plug that goes into the controller are secure. If you are not getting the green light when you hold the plate against the bit, I would suggest that there is a connection issue, not a software issue.
@Bill I sympathize, Bill. The wires do loosen. I had the same issue and it was the screw holding the wire onto the magnet. Others have had the connection in the banana plug loosen.
This may not be your problem, but it can’t hurt to take a few minutes to check it out.
