I use a wired PS3 controller, have been able to map all the buttons I need.
Running Fedora 34 KDE on an old laptop.
Hi Folks,
Hope everyone is doing fabulous and are making some neat projects. We’ve recently planned out some new features and improvements we want to tackle for gamepad/joystick support in gSender and we are pretty excited about it. Here is a quick breakdown of some of them:
Although these features above will make some great additions to the gamepad/joystick, there could be other features that some people would like. If you have any suggestions or requests please let me know I’m more than happy to take them into consideration.
Thanks!
Walid
Walid,
Thanks for the info and I have a suggestion for the future. What I was wanting to do is map the left stick to x/y (which is does already) and map the right stick to Z. That would mimic the controls of most video games that I’ve played. I have no idea how/if others would like that type of control or not, but figured I’d share the idea. I mapped the Z jog to the directional pad and that works well (I just need to retrain my brain a bit).
Another suggestion is around the probe shortcuts. Right now there is only a “start probe” option and it will probe based on what option is selected on the screen. I often do 2 probe runs, one for X/Y on the part and one for Z on the table. It would be nice to be able to shortcut to a specific probe action directly without having to go back to the screen.
I’ll keep playing with the setup and see if I have other suggestions. I have a lot to learn on the package overall still, I had been using UGS from 2019 until I saw this thread and decided to try your package. I like a lot of the features you and the team built into it, great work.
What WIRED controllers have been tested and approved for use with latest gSender?
A specific wired controller we’ve tested out was the QUMOX Wired USB Gamepad, a PlayStation-like controller. We did notice some inconsistencies with it when testing it a while back which is why we don’t recommend it.
Another one is the PDP Gaming Wired Controller, an Xbox-like controller. It works quite well and we still use it today for testing at times.
We’ve also tested a PS5 controller via USB, and it worked fine.
The two controllers we do recommend are in the documentation here:
They are both wireless by using a USB dongle, but they work quite well and we confidently use them in our testing phases.
Hi,
I am trying to use an 8bitdo Ultimate Bluetooth controller under Mac OS (14.4.1) with Gsender (1.4.7) but it doesn’t recognize the gamepad.
I managed to make it installed on the os via Bluetooth but not to be detected by Gsender.
The controller is the following one:
Thanks!
It should recognize the controller, but being a Bluetooth connection might cause some connectivity issues. Could you try this online tool out and see if your controller is detected there or not:
Hi Walid,
I tested and the tester doesn’t recognize the pad under Brave 1.65.133 (Chrome) but does under Safari (17.4.1).
Even if detected under safari, it still doesn’t detect the pad under Gsender.
Weird.
One additional thing, the tester does not detect the buttons correctly. On the letter cross (A,Y,X,B), the following are detected:
