Hi team -
Just installed gsender and hooked it up to my machine (750x750 NewCarve running Openbuilds Blackbox x32 controller)
I tested movement when I first connected, and everything moved fine.
Went to run a job and after moving the Y axis back to the left front (which went fine) I tried to move the Z down. A that point, it moved the Z axis down .001 at a time and the cancel movement button won’t work. I have to reset the controller and restart gsender to make it stop.
I installed openbuilds control software and everything on the machine is fine, so it’s some sort of setting or issue with gsender.
Any ideas? Thanks!
