I am using Gsender on windows 10 with my homemade cnc.
I am having the issue of GRBL disconnecting randomly during a job. I make crib boards so I use the same gcode over and over, attached is the gcode for drilling the 367 holes needed for one board. It randomly will stop in the middle because the machine disconnects. I have to disconnect the USB and plug it back in before I can reconnect to the machine. By random, I mean it happens after 10 holes sometimes, sometimes it finished two boards. Almost always it disconnects while moving from hole to hole at rapid speed.
My setup:
Homemade cnc with Arduino Uno with shield running A4988 drivers. 500w air cooled spindle.
Power for the Arduino is from a 24V power supply and power for the spindle is from its own power supply. Both power supplies use the same power cord to get power.
What I have tried:
Replaced USB cable, new one is shielded.
Reduced max rate on all axis’s way down to 1000mm/min
Tried a different computer to run the gcode
separated spindle power wires from stepper wires
Replaced Arduino with a new Arduino
Tried UGS and Gsender
Tried powered usb hub
Turned all power saving off for the computer and disabled any power saving for usb ports
I currently have ferrites on order, where should I put these. I believe I should put 1 on each end of the USB cable, should I put them on each stepper cable and spindle power cable?
I have multiple 3D printers and laser engravers and have never had this issue with those. Is there anything else anyone can recommend to try? I have thought about using shielded cat 6 cables for the stepper motors, would this help? How about changing the power so that I plug in different cables into different circuits for the 24V power supply and spindle power supply? Should I be grounding the Arduino in some way?
@hardingb The simplest first step is to make sure that you have turned OFF all USB power saving/controlling features in Windows. Do this in the power settings tab of control panel AND in device manager as well. This may not solve your problem, unfortunately. However, it is a very common cause of disconnects, so it’s a reasonable first step.
If you search on this forum and elsewhere on the internet, you will find many, many articles and papers on the problems of grbl-controlled machines freezing and/or disconnecting while cutting. There doesn’t seem to be a one size fits all solution. Major culprits seem to be static and emi interference. With luck one or more of the solutions that you find will solve your particular problem. I wish that I could be more helpful.
I had good luck with putting my router and shop vac on a separate household circuit - borders on superstition I suppose, but does give some isolation / impedance between the electronics and the noisy brushed motors in the router and vac. If you don’t have a separate circuit nearby, try using an extension cord to get to another circuit - cheapest / easiest experiment to run. I think there was someone else on the forum who did try that and it was a temporary resolution.
I have been looking into power supply filtering - I would like to try something out that way, but I don’t want to just throw money / parts at the situation without having a stronger understanding of what may be happening.
My ideal case would be to run a test where I can measure and replicate the problem (say with an oscilloscope + disconnection happening), and then demonstrate the effectiveness of the solution - but I’m not sure if I can get my hands on instrumentation to do so.
Please if you find the solution for lt, take a moment to post here. While I don’t have that particular problem currently, I may in the future. My only suggestion is a good quality USB cable, but I am sure you already have that covered.
I did a number of things yesterday to work on the issue and I think I have found a solution.
Below is what I did in order:
Isolated the electronics from the spindle. I have not been running a shop vac during a job to take that out of the picture. I placed each on its own circuit. I did get a program to run for a few minutes and was optimistic but it failed.
Next I changed the z-axis stepper cable to a shielded cable. This did not work as well.
Next my ferrites finally arrived and I put them everywhere. I got a package of 12 and I put one on each end of my usb cable (I think this was the solution) but I also put one on each end of my stepper motor cables and my spindle cable. This seems to have fixed the job. I ran a 40min job, 25min job, and 2hr job all without any problems.
I cannot guarantee it was just the ferrites and not a combination of the things I did, but the ferrites were the final thing that eliminated the problem.
I had this problem and I found a fix. I took the router power cable out of the cable chain and ran the cord to the front left side (opposite side from the controller)
. Since then i haven’t had a disconnect.
Apparently it has to with the router brushes inducing extra voltage/current into the wires going into the controller.
