Hello
So, I am having 2 issues. I will report this one here since its long winded.
Basically, I am having a performance/timing issue?
The keyboard is Wireless, so there is a chance what I am seeing is delayed reaction between the Keyboard and the PI. That said, Its super noticeable on the PI, not so much in UGS
I have :
8 gig Raspberry pi 4
UGS (installed)
gSender installed (installed)
Wireless Logitech keyboard with touchpad.
22" TV with HDMI
gSender on Raspberry
Problem:
When I issue a move command on the PI and gSender, it lags behind in the reaction of the movement, not only that. the screen updates very slowly.
So when you click Move,
ā There is a 1-2 second pause in the movement.
ā There is a 3-4 second pause in the screen changing from idle to movement.
the same behavior is repeated on the stops.
Video to Support the behavior.
UGS on Raspberry
ā There is a 1 second pause in the movement.
ā There is a 1 second pause in the screen changing from idle to movement.
Why this is an issue :
I have seen this problem more so on the PI Version, but I see it randomly on the Windows version.
From time to time, gSender seems to get stuck and will not stop sending the command or just go till it rams into the beds or top.
I believe it gets reported more often as there isnt as many people using the Pi.
just my opinion.
