gSender 6.8 Beta Windows - Go XYZ 0 Moves Z after moving X and Y
@chrismakesstuff
I dont know if this has always been this way, but I have been trying to reproduce a problem with my Z travel, and I just snapped a 1/4 inch bit in half doing this.
The Question I have is, since when did the go XYZ0 button Travel X and Y, and then Z to go back to zero?
I am exploring a problem, where I am running a program, then stopping it, and when I hit stop, move the Z down 3 button presses, when I hit the GOTO XYZ 0 button or hit the Start Button, the Z gets reset back to 0 before it ever moves. then it seems to Plunge into the work, because the new Z is at Zero, when it should be at 22.
So, Ignoring what I just said above, as I am still troubleshooting that.
right now, in 6.8, if I move my head to Anywhere , and move my head down a few presses.
When I hit the GOTO home, I KIND of expect it to go to SAFE Z, or at least maybe Z 0, before trying to move the X and Y
but nope!, Moves, X and Y, then Z.
which means I have broken a bit as it crashed into the work
i can make a video, if no one can reproduce.\
Are you going home or to XYZ0?
XYZ0 is your work zero. It makes sense that it would move X and Y first and then, typically, move down to Z0.
I personally don’t believe
Any travel in X or Y should happen unless the Zed is put into a safe mode
In my scenario that is in the negative because I’ve stopped the program
Because it most of the the X and the Y first it basically plows into any of my work piece because the Zed is in a negative
I understand what you’re saying. I’m just saying that the behavior you’re seeing is what the button is programmed to do.
I hear what your saying, not sure I agree but this is why I tagged Chris in the comments.
I am by no means an expert, but I think the general rule is. Move the Z out of the way, before trying to move X and Y.
I say this alot in my job.
I report bugs, and inconsistencies, it’s up to the product owner to make a decision. Good or bad, once a decision is made I will abide by it
I’m with you. I’ve never seen a reason to use Go to XYZ0.
Also, if you’re stopping below Z zero, I’d recommend enabling parking and wiring a feedhold switch.
Do you have your safe height set in options? If safe height is not 0, goto XYZ0 will retract by the set distance on Z before moving XY and then returning Z back down to Z0.
As mentioned, generally XYZ does do XY and then Z to avoid dragging the bit across the work surface when moving back to work origin.
Funny you mention this
I know I had it set to 8mm.
But I went and un insalled last week and cleaned up everything .
I need to re check
SOO! YUP!
I am the moron!!
It did work before. but as Kevin pointed out, I didnt have my safe height set.
Well, I did, but part of my previous uninstall, and re-install I guess I forgot to check it!
@chrismakesstuff you can send this post to the delete pile.
or maybe there should be a best practice post someplace that explain how someone can shoot themselves in the foot :slight_smile:
Thanks!
p.s.
As Bugs Bunny would say
“What a Maroon!!”
@Menglor I’m glad that it turned out to be something simple, Stephen. Doh, I didn’t mean that YOU were something simple. :grinning: :grinning:
My wife says I am complicated!
Then she says I am simple.
Who knows anymore :slight_smile:
