gSender and xyz probe
I made my own XYZ touch plate. Other than setting up the wall thicknesses in gSender, do I need any additional g-code? Not sure if the overall size of the touch plate needs to be inputted somewhere.
btw…I’ll be using it on a Fox Alien Masuter Pro that has been upgraded with NEMA 23 motors.
Thanks.
Hey Brian,
You can enter the dimensions of your block into the standard block design section at settings.
