Gsender Anomolies All over the place
Has anyone had any success using gsender on a Masuter Pro?
I bought a longmiil and a Masuter pro but I’m trying to get gsender to work on the masuter while I build the longmill. gsender behavior seems to be all over the place on the Masuter machine. For one thing, I have noticed that if the gantry is left ON the limit switches, it throws an error 8 when you hit HOME, every time. If I unlock and jog away from the limit switches, it homes just fine.
And, it also throws the reset while in motion quite often. Frustrating. I have found only one reference to this in my searches.
ALSO, when I generate a surfacing gcode, and hit the outline button, it jogs to the right and then halfway back, it stops and stutters as if it is missing steps and wont stop until I turn off the power.
I can jog the machine around just fine.
I have had limits enabled and soft limits off although I have tried it both ways.
Machine bed size is correct.
UGS does not throw these errors when jogging around.
Any ideas as to what I might be missing?
Thanks in advance
@Windlasher Welcome to the group, Vincent.
I’ve moved your post to the gSender question category. While you mention UGS in your closing line, your question directly relates to the use of gSender with your Masuter Pro.
thank you. Wasnt sure where to put it.
