Hello,
About the “Connect to machine” Button.
Since i only have one CNC Machine/Longmill, should GSender connect with a single button click without requiring to select the actual Com Port/Machine? (A bit like the Firmware Dialog that states "Connect to last active port)
I am not aware that my Comport changes over time.
Not sure if people are working with multiple machine (It was discussed in one Youtube Live Event a few months ago)
In general settings, there is a “Re-connect automatically” toggle under connection that will do what you’re asking - handy if you only have a single machine on the same port.
Cheers,
Kevin
You Are Absolutely right.
I can’t figure out why i did not see this before
Tested and it works! thanks!
