Gsender crashes
Afer installing gsender (second time) and crashes windows 10. Reinstall required both. Lets me do all configuration but first gcore crashes it. Very frustrating. Build new machine and try to start first job maschine crashes. Core I3 2g ram. Gsender latest version. Arduino uno controller.
@rippe71 Welcome to the group.
Am I understanding correctly that you have a self-built CNC? Your controller is an arduino uno. What version of grbl have you flashed it with?
Can you provide a bit more information about the crashes?
1 . Are you trying connect with grbl and not grblHal?
2. When gSender “crashes”, does Windows freeze? Can you use task manager to close gSender?
3. When you re-installed gSender, did you follow the advice on this forum regarding re-naming files before simply installing gSender again.
4. When you say that you re-installed “both”, do you mean that you did a complete re-install of windows 10? Do you have the ESA for windows 10?
5, Your PC is running a Core I3 processor. Are you saying that you have installed only 2Gb of ram?
This and any other information that you can provide will help members provide more valuable advice.
@rippe71 @gwilki - I don’t know if you remember Grant but I had a similar issue back in September of last year with 1.5.5. Never did figure it out but it all of a sudden just installed correctly. It took about 5-8 (don’t remember how many) tries over a two day period. Tried several times to re-download and still failed. BSOD each time with no feedback. My PC has 16gb storage with 1.5tb disk space so memory and disk was not an issue.
@Heyward43 I had forgotten that, H. Thanks for reminding me. Your experience may help @rippe71 overcome his problem.
