gSender Edge local versus remote
When using gSender Edge and opening either a local or remote job, the other doesn’t always track the status. If I start a job on the local and then open up the webpage remotely, It shows the router moving, but not the file that’s running or even connection status. If I select to connect to the Longmill, gSender stops the job. I can restart fresh locally and if the remote window is already open, then the status updates as expected, but if you hit refresh in the browser, it loses status.
I tested with 1.24 and just upgraded to 1.25 with same behavior
@hamanjam the part you mention about
has since been fixed in newer versions of gSender (I think as of 1.5.2)
I suspect some of your other comments might’ve also been since updated. Though one note is that no matter what when you open up the Remote browser it will always start as ‘disconnected’ since the remote browser is always running it’s own version of gSender so you need to connect that version separately from the one running on your main computer :+1:
I had completely forgotten about this thread. All of this is irrelevant at this point as they were referring to v1.2. This can be considered solved as if 1.4 and now 1.5 released
