Gsender jog controls not working
Hi All,
I have a Longmill Mk1 30x30 using gsender to control it. A year half a go I moved and packed up my shop including the longmill. Its taken me a 18 months to build my new shop and finally this week uncrated the longmill. So I have it setup, updated to the newest version of gsender and now none of the jogging controls work. If load a file and start the spindle jogs so I know there is power to motors.
I have reloaded gsender a couple of times and reflashed the firmware on the longboard. I would appreciate if someone can help me out to get things reconfigured. thx
Hey DCS,
What version of g-sender did you have 18 months ago?
Is it an idea to reinstall an older version, just to see?
Here you can download what you pro ably had running.
@Dcswabey Since you are using the current version of gSender now, be sure that you are connecting via grbl and not grblHal.
Yup…already checked to confirm I am using grbl.
Thx guys, I played around reloading and uninstalling several older versions, found couple of older related threads and evenually got the latest version running properly…cant wait to get the longmill into production in the new shop!
try $rst=$ on the console press run this should reset everything
