Good morning
I am having an issue with gsender loosing connection. I move my router out of the way so I can put another project in place. When I go back to move it into place to set my Z axis it has lost connection so I have to turn Gsender off and back on and re home. This has just started happening the past 2 projects.
Any insight w
How are you moving “router out of the way?” How long between moving your router and putting “another project in place?”
Do you have a problem with losing connection when moving your router to anywhere else?
Sorry I am just seeing this reply. It only happens randomly> There are times where I will let it sit for an hour or so come back to it and it will move fine but other times i will raise the z axis to change the bit and it won’t let me do anything so I have to shut it down and rehome it and continue.
Thanks.
