GSender mm Adjustments
Hello:
Can Gsender surfacing routine do partial mm increments or am I doing something wrong? It seems to only accept numbers in whole numbers. What if I just want to skim off the very top of something? Thanks
You should be able to enter decimal values. I just did this yesterday at 0.25mm.
Hey @Windlasher,
If you are using the main gSender 1.4.12 build, it should be working as expected, but we do have a bug that we are fixing in the latest version of gSender 1.5.0 Edge 7.
Which version are you using?
Cheers,
Stephen
Im using version 1.412. Ill give it a try.
