i put in reasonable values. Press create gcode and I am immediately returned to main screen Help!
Hi
Verion 1.0.2 of gsender works for me , so what kind of trouble are you having.
Andy
Hi:
I take it back, there certainly is a problem with the surfacing routine, i decided to resurface my waste board after some 230 lines it stops and reports a feed errorā¦
Not sure whatās going on
Andy
the surfacing option was not creating G-code ā nada, zip, WTF. it just returned to main page. now it is creating G-code. i still have strange things happening. if I try to surface 5.5" x 8.5" blank of rough sawn wood it works fine but if I surface an 5" x 8" blank with remainder of settings identical (it saves about 30s) it leaves a āMohawkā in the middle as if it doesnāt need final pass
Hi
It seems to have issues at the momentā¦
Prior the surfacing routine being incorporated into gsender , we used the routine discussed her
It is efficient and does work, I went back to it after gsender gave me errors
Andy
I did too. then gsender started to work Iām confused but thatās normal. Generally I like gsender except it doesnāt like my arrow keys to jog x & y. who ever designed gsenderās graffics has really small fingers or uses a really big touch screen or a mouse. Thanks for the thoughts. Brian
Howdy,
If youāre still experiencing some issues with surfacing, would you mind sending me a screenshot of the configuration you had (dimensions, stepover, layer depth, etc) so I can do some further testing on it?
Thanks!
Walid
sure iāll do that in the morningā¦
Andy
