I have another question, has anyone had a problem with the Z axis not moving during calibration?
I’m using the new gSender update and while I was trying to check my calibration in Z axis, the axis intermittently will not move when I select the button to move down 30 mm.
Could it be because I am set up for inches or could it be a glitch in the new gSender???
I had the same problem. It started after I accepted a recommended change to the motor speeds. To fix it I had to go back into Gsender, back to “Calibrate” and then to “Movement Tuning” where I was able to reset it to the default settings.
