I used Cut2d v10.5
the post processor was Gcode ATC (mm)
I took a look at the post processor and it seems the ‘H’ relates to the Post processor, the comments say so
see below
- G Code ATC - Vectric machine output configuration file
- History
- Who When What
- Tony 02/08/2005 Written
- Tony 12/03/2006 Added ATC option for Tommy Coates
- Tony 02/08/2006 Added H offset for ATC
- Tony 07/08/2006 Created mm version
POST_NAME = “G Code ATC (mm) (*.gcode)”
FILE_EXTENSION = “gcode”
UNITS = “MM”
- Line terminating characters
LINE_ENDING = “[13][10]”
- Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
- Block definitions for toolpath output
- Commands output at the start of the file
begin HEADER
“T[T]M6”
“G17”
“G0[ZH]H[T]”
“G0[XH][YH][S]M3”
- Commands output at toolchange
begin TOOLCHANGE
“M0”
“M06T[T]”
“G43H[T]”
“[S]M03”
- Commands output for rapid moves
begin RAPID_MOVE
“G0[X][Y][Z]”
- Commands output for the first feed rate move
begin FIRST_FEED_MOVE
“G1[X][Y][Z][F]”
- Commands output for feed rate moves
begin FEED_MOVE
“[X][Y][Z]”
- Commands output at the end of the file
begin FOOTER
“G0[ZH]”
“G0[XH][YH]”
“M30”
