GSender accepts loading of file (no problem all day…)
GSender displays file as loaded
GSender will “Outline” project correctly
When told to “Run” file GSender runs the last surfacing path…
Rebooted GSender
When told to “Run” file GSender turns on router, but router does not move
Rebooted LongMill
Rebooted control computer
Problem remains
Powered down everything
Powered up everything
When told to “Run” file GSender turns on router, but router does not move.
Won’t work when “Outline” isn’t done.
Manual controls all work.
I tried again with a completely different tool path. Everything was shutdown. I restarted the works, created a new tool path and it completed the path successfully.
If you want a copy of the tool path that didn’t work, let me know.
@qrupc02 I’m not competent to diagnose it, but there are members here who are. If you want to post the gcode file, they may be able to help you avoid similar problems in the future.
