Had my Longmill 1 year. Basically never made anything with it. Feeds and Speeds and Machine troubles
Sweet, you started a fire! I haven’t done that yet.
Take a breath
Looks like we need to break this down to the steps you pointed out.
I just put the Longmill together per instructions and didn’t worry too much about Machinist accuracy right away. Someone else will have to chime in on those issues. I do use the Makita router. It is very light…
I would put the 1/8" bit away and start with a 1/4" bit on some cheap 2x4 material. You can surface with a 1/4" bit also. I use number 4 (not sure what that is on a spindle) on the Makita for speed and 120 IPM for feed with a 1/4" bit with at least a .0625" (usually 0.125") cut depth. Practice with the 1/4" bit a couple of times with surfacing an see how it works.
You have taken a machine that the company has done pain stacking engineering on with 1000’s of hours of beta testing on top of that. Then added a spindle to it that is much heavier than the router it is designed for plus a heavier attachment point. That alone is possibly exceeding the constraints of the machine. It would put excess wear on the V wheels plus bind them up as the machine moves back in forth in all directions. That isn’t the machines fault.
I had my machine set up new and didn’t once tram it only squared the machine during set up with the process of making sure it was square with the plywood and the gantry to the side rails. The machine ran perfect. I suspect you over loaded it. Plain and Simple. Now I don’t know the specs on your spindle so I can’t say for sure. What you said in your post that what it sounds like to me.
@thunderingdragon - Please don’t be too quick to jump on @GregsReinventions. Greg is correct in his statement. Granted there is not much info on Sienci’s web site but they do state that they are not recommended due to their weight. This information is stated in the Resources pages under “Router/Spindles”. As for the 80mm spindle mount it is for one of the Bosch routers that is recommended, not specifically for a spindle. They do not state anywhere that you can not use one but it is definitely not recommended. That means to me that you do so at your own risk. I, like others, would love to use a spindle but due to the info about the weight I won’t be pursuing that with the original LongMill.
Thank you Sir. I was a Beta Tester and I know what these machines can do and take the gantry can twist with too much weight on them. They are not meant to take a spindle that are much heavier than a few ounces more than a trim router. I was there in the shop during some of the design and trouble shooting . 1000’s of these things are in the market place and very few if any have encountered problems as severe as this. I don’t believe my statement was harsh or even mean just truthful and factual. If thats not what you want to hear that isn’t my fault. If you have broke your machine because of this then I do not represent Sienci Labs or anyone there but I seriously doubt will cover it in any kind warranty. Sorry
@Blunderpunk I assume that you have contacted Sienci tech support with your issues. Did they help at all?
One thing that you may not have already checked is the dimensions of your V wheels. There was a Sienci blog post some time ago about a batch of wheels that they received that were not in spec. They were too small. Some of these got out to customers before Sienci found it out. With these wheels, it was impossible to get the adjustment right. This may be old news to you, and it’s more than likely that, when you contacted Sienci tech support, they asked you to measure your wheels, but I thought that I would throw it out there anyway.
@Blunderpunk You’ve certainly had more than your share of problems with the Mill. I’ll be interested to see your linear guide setup. I’ve looked at the guides, but I am not competent to re-design the Mill to use them. Good luck.
Depending on how things go I may be completely on my own designing a new CNC router entirely.
The lead screws are aligned with the center of the angle iron so I cannot just weld a plate to cover it for a flat surface for linear rails.
I may have to replace them with steel square tubes to have a surface the linear rails can mount to, and then there’s the issue of the anti-backlash nut being difficult to reach and adjust. The anti-backlash nut can have a spacer made when attaching it to align it properly, but adjusting it would prove to be difficult.
Alternatively I could just upgade to ball screws as well, but I am getting to the point where I am so far away from what the Longmill is it’s basically its own thing, so I am debating the best method of doing this still.
So the tricky part is finding linear rails that are small enough in width to fit 2 per each side where there is enough room to allow the anti-backlash nut to be attached - or the ball screw nut. Whatever I decide on going with.
I’m still baffled by anyone’s success with this. The machine is impossible square the spindle from the factory. You can adjust hose eccentric nuts all you want but that messes with the clamping force available. It is a constant battle between clamping down and being aligned, and if its too tight the carriage just stalls the motors.
@Blunderpunk FWIW, if I were looking to make the kind of changes that you are, I would either start from scratch or find a CNC that already has the features that I want. I’ve done a lot of “thing” modifying over the years, and while some have turned out OK, most have been a lesson in futility, costing more in time and money than the results warranted. That said, I can only base my decisions on my resources. Yours are clearly much different.
In terms of “bafflement”, I guess that I am more baffled by your lack of success than by the success of thousands of others. I mean no offence, but let’s face it, you are somewhat the odd man out here. The Long Mill and many other hobbyist machines use components like adjustable delrin wheels and they seem to work well for many, many users over years of operation. I don’t particularly like them, either, but my research before buying the LM showed them in use by many makers and they did not seem to provoke screaming reactions. My experience has been the norm. I find them finicky, but I am able to do quite intricate projects with my LM. My issues have never been the lack of precision brought about by the wheels.
I have no idea of your background. I came into this with a fair background in woodworking, and a peripheral knowledge of commercial woodworking CNC use. My expectations of the LM were based on that. Some here seem to be criticizing the LM based on a machinist’s eye for precision that is simply not possible on a CNC machine of this calibre. Nor are those expectations reasonable when working in wood - a material that moves more during a long carve than any lack of precision in the Mill will cause. I have some experience with a $150,000 woodworking CNC and it is not capable of achieving the one ten thousandth of a inch precision that some owners here seem to expect of the Mill. With respect, I believe your expectations are out of line with what these type of machines can deliver. That is not the “fault” of the machine nor of you. It is, in my view, simply the reality of the situation.
I sincerely wish you luck in your pursuit of a CNC router that you can enjoy using. If this is a hobby for you, it should, after all is said and done, be fun. If it is to be a business, it needs to be a machine from which you can earn a profit. While those two criteria are not mutually exclusive, they are somewhat contrary to one another. So, choosing or building your next machine needs, first and foremost I believe, to be influenced by what you are going use it for.
Here endeth the epistle. :grinning:
I had a problem with a bad batch of wheels (customer service did take care of this)but other then that there is one problem I wished Longmill would have warrantied.
There is a “glitch” that the manual speaks of when setting the xyz.
What it does is crash the bit through (it tries too)the aluminum plate (or even the wood AFTER the z is set to 0) when setting the xy&z.
It broke one of the screws inside of my gantry which I cannot get to and has broken bits.
Had to use paper out of fear for a while but I didn’t get much help from customer service. They spoke of sending pictures and there is no way I can send a picture of that. It was installed at the factory.
Not to mention customer support only works when I work and I cant talk on the phone at work. That is aggravating.
Additionally there is one more nuisance which the programmers need to fix.
When gSender updates there is NOTHING to let me know it is done! It can go on for hours and hours and hours and NEVER lets the customer know it is done. All programs let you know updating is done by stopping the update. But not Scienci.
Because of this I don’t even know if mine is updated??
That should have been fixed long ago but it still isn’t.
In the mean time, I have a broken gantry because of a glitch which Scienci acknowledges but yet I cant get fixed!!
Makes it hard to stay a customer.
And here is a little tip for the programmers.
Often times the laptop is far away from the router. Having ONE button to stop and start the laser test is much better. Just loop (Count == 0 first) Count 1 for on Count 2 for OFF and the same button can do both on and off functions.
Even at the top of the gantry the laser can burn the wood and not having to look for the OFF(changing position of cursor) button while finding the center is a huge help and can save burning in the wood. Don’t know why they haven’t thought of that.
