Height Map/Surface Map and Arc slow speed control
Height mapping would be a big plus. Also, the ability to slow the feed rate when the code is performing arcs of a certain degree would be very useful as well.
Thanks and great work!
@778 WRT to slowing the speed rate, you can do this with the feed rate +/- buttons or the slider. Do you mean that you want gSender to be able to do that automatically by reading the arc commands in the gcode?
I’ll defer to @KGN to address that, but I would think the difficulty would be what value to use for any given arc. Users may not want the same value.
You could always edit the gcode to insert feed rates where you want them.
A post was merged into an existing topic: Heightmap gSender
