I am unable to home my machine. I constantly get a 10 code error. Also none of the other sensors seem to light up. I have readjusted to Z sensor and the X are correctly installed.
@LarryLSimmons Members will not more information if they are to offer advice.
- What machine are you running?
- What controller are your using?
- If you are using gSender, what version?
- Is this a new problem or have you never been able to home your machine?
@LarryLSimmons If SLB and gSender, you have the ability to home each axes separately. That could give you an indication if a particular sensor is causing problems.
When in carve mode, at the top right, thereโs a toggle under the zero coordinates. Enable that temporarily. Youโll see that the buttons on the left change to HX, HY, HZ. That will allow you to home each axis separately.
Altmill 4x4 with gsender 1.5.4. This was the first time I tried to home the machine
continuing to trouble shoot. Here are the errors I am seeing.
Right x axis works fine
Left X axis fails with alarm 10 E stop asserted.
Y Axis front. Alarm 10 e stop asserted and it hits the hard stop.
Y Axis rear. Alarm 1.
Z axis down alarm 10 E stop asserted
Z Axis up alarm1
Homing-alarm 15 homing fail could not find second limit switch
I can manually trigger the sensors with the wrench
Not sure how to fix this
