How to St Z Axis Probe Height
I’m setting up Gsender 1.4.11 on a Windows 10 PC for the first time. I know I have to set the z axis probe height in order for it to work correctly. However, I can’t find where I do that. I tried Gsender’s Help but the box where I enter the height is not where Help says it is.
I don’t know if it was relocated in a version change/update or if I’m really staring right at it and just don’t see it. I can use the probe function to test for the probe, but it’s of no use if I can’t enter the measured probe height.
Can someone kindly point me to it?
Many thanks,
Ken
So Phisai, Thailand
I didn’t quite understand your question but …
Click on the gear symbol on the far right top of the screen, then go to ‘probe’ and you can configure everything there.
Hi Jens,
Thanks. I’ll try that click on the gear trick tomorrow. Was too busy with other things, plus it’s unbearably hot (35 degC) in the workshop!
Thanks again!
Ken
