Jog control arrows, not working
I just downloaded G sender 1.3.10 – edge.
I have Microsoft windows 64 bit system.
For whatever reason when I click on the XY or Z jog control arrows, they highlight, but do not work. I can, however use my touchscreen and put my finger on the XY or Z arrows and they work just fine.
Everything else seems to work just fine.
Any help on? This would be greatly appreciated. By the way, I’m extremely new to this.
Thank You
Jim
@Jim65 Welcome to the group, Jim.
It would help to know what CNC machine you are using and what controller you are using.
Also, why have you chosen to use a version of gSender that is about 10 months old rather than the current version, which is 1.4.9?
The CNC machine is the Long Mill 48 x 30.
The controller is from scenic labs.
I downloaded and installed version 1.4.9.
Still having the same problem. Plus now the XY move, Z move and speed do not show any numbers they show NaN. Also the touch screen no longer works.
Thanks for any help you can give.
Jim
Is there a way to get back to a version of gsender that worked for me?
Jim
@Jim65 You can uninstall the active version and download the version that you want to revert to. Before installing it, rename your .sender_rc file - you can find it in C:/Users/{your user name}/.sender_rc.
