I using a cheap āUSB joystick boardā all the inputs work in gSend. I can HOME from the Screen button, keyboard shortcut, and terminal $H.
But I canāt trigger a HOME from any joystick button I assign to it.
I monitored the terminal and the nothing gets sent when I try to HOME from the joystick. As a further test I created a one line macro āmyhomeā with the oneline ā$Hā if I click the onscreen macro āmyhomeā the macro work, but if I set a joystick button to trigger that macro it also doesnāt activate. I can do everything I need via my homemade joystick box except trigger HOMING.
EDIT forgot to add version 1.1.7
Are you sure the button works? Try assigning a different function to the button as a test. Might be a good rule out.
Iām 100% sure the buttons work. I did try to reassign to different buttons. This is the only command that doesnāt work. I normally use UGS and have been trying to switch to Gsender. This is the only thing keeping me from switching.
Also when configuring it, when I click the button it shows on the test screen which button I clicked, so Gsend is getting the signal.
Hmm. That was all I could come up with. There are a lot of super savvy folks around here, though, so Iām sure someone else will be more helpful!
I know this is an old topic, but I just retested this and itās definitely working as expected now, probably just a bug that was shortly fixed and the thread was just never closed ![]()
