Keyboard shortcut jogging not working
gSender 1.2.2
I searched the forum and saw someone had the similar issue but didn’t see a solution.
So when using the mouse to click jog, it’s moving fine, but when using keyboard shortcut (holding down shift+arrow), it only moves a tiny bit then stops. It does not give the continuous motion as while using the mouse.
Using the Logitech F710 has the same result.
I tried it on gSender 1.2.1 and it’s the same
This should be fixed in the next main release.
