Loading code w/o Gsender computer
If I have the 48x30 Longmill, and do my programming in Vectric, then save it to memory stick, what’s the easiest way to load it into the Longmill? Do I need a separate computer? Thanks so much….. Jeff
@JPopa Welcome to the group, Jeff.
You need a computer connected to the Long Mill controller. It can be the same computer as the one on which you do your Vectric design, or a separate dedicated one. In Vectric, you will create your gcode files, using either the grbl mm or the grbl inch post processor. You can transfer those files to a separate computer connected to the Long Mill, then run them.
