Longmill MK2 30x30 Tiling with Easel
I created a design in Easel that requires tiling. I exported the gcode and imported it into gSender v1.5 (newest version). the only thing that is visible in gSender is the first tile, i’m not sure where the second tile is or how to access it.
@rickholdway Hello and welcome to the forum!
I don’t have experience with Easel but I would expect that you would have two toolpaths and two G-code files. I think tiling makes sense to have two files as you have stop and move your stock etc.
EDIT: Should have said two or more toolpaths depending on how many tiles the job is. I just found this on tiling in Vectric. In the description he mentions this…
’ll show you the entire toolpath tiling process, step by step, and discuss important considerations along the way. I’ll then wrap things up by showing you the finished project, and save the G-code for each toolpath.
So at least in Vectric it sounds like it would be multiple files. I didn’t watch the video just read the description.
Thanks. That’s what i was expecting, but Easel only had 1 tool path to download. I will reach out to Easel and see what they say. Thanks again.
If you haven’t figure this out yet or for others. Each tile creates gcode. So if your project is three tiles you’ll have three separate gcodes files. If you have both a roughing pass and a finishing (detail) path then for a three tile project you’ll have six gcode files. All six files will need to be downloaded separately. You need to select each tile in Easel and download two separate files. A roughing file and detail file. You can do each tiles roughing and detail file together as a zip if you want. I find it easier to just download each file separately.
