G Sender defaulted my machine size to 30X30. How do I change it to 48X30
Go into gsender firmware, and change to your machine size. Firmware is at the top of the screen.
Do you have to set the probe every time?
No, set it and then save the changes. I don’t think you have to reboot the controler, but it wouldn’t hurt once the new settings are saved.
Maybe I read it wrong. When setting the probe, set the x&y once, and the z each time you change bets, for each job. Setting the machine size you only need to do that once. Hope that makes cense.
Thank you very much.
