Does anyone here use Rapidchange ATC macros with gsender 1,5,7 or later? In my setup the macros act weird, I would like to compare. M64/M64 to open/close the lid does not start at tool change, probing seems to run 2 o3 times on same tool, not sure if its gsender too lchange process or maybe something in the macro?
Maybe a dumb question…but are you using 1.6? I think that is the version you need…maybe im just confused by the question.
I just dipped a toe in the water with the RATC Solo unit. Looking forward to setting up once I’m back from travel tomorrow, so looking forward to learning if there are any hangups with gSender macros. Will likely snag a linear unit in the not-too-distant future if all works as expected.
