LM MK2 30x30
gSender 1.5.3
I have only just upgraded from 1.2.2. I programed a handful of Macros that send the router and laser to different registration points. No matter the size of my window (I have an ultrawide monitor) the Names of each macro are cut short while I have long open spaces in each button. “Spindle to Registration” is just “Spindle to…” mean while there is easily 1.75” of space on both sides of said button. I have to mouse over each one to read them before I click. I am aware I could short hand them, but the amount of screen real-estate says I should be able to just have the whole name on each button.
Hi @Samuel.W, in the 1.5.5 update we made some changes to allow the macro names to be a bit longer, but unfortunately haven’t had the time yet to implement a full fix for wider monitors. Will reply back once we do
That sounds great! Thank you so much.
@Samuel.W great news, as of the upcoming 1.6.0 Main release we’ve now finally got the macros set up so that the title length is adaptable to the macro box size, which itself is adaptable to the width of the gSender window. This should finally give a good option to see more of the title if your screen permits it. Once the main version releases, try it out and let us know what you think! If you see any issues with its implementation or functionality, just open up a new topic to let us know
