Hi Can I used my makita trimmer 28000 tour if the speed is not variable
@Michelmike Welcome to the group, Michel. Bienvenu.
I canβt find any online reference to that trimmer. Can you provide a link?
Two things come to mind: Will it fit in any of the Long Mill brackets? Also, being a single speed may cause some issues with your feeds and speeds calculations. Much will depend on the material you intend to cut and the bits you intend to use. With more information, Iβm sure that there are others here who will be able to advise you.
Edit: Is this it?
