Measurements not adding up
Hello my CNC Brothers & Sisters.
I have a strange thing happening in what i can only describe as a measurement issue.
Ok, let me try and explain…
In Vcarve, I’ll set up my project, ex:
Using MDF sheet that measures
(W)614mm x (H)625mm
I’ll design my project and set my tool path (pocket) that creates a 20mm boarder around the entire piece so i can resin pour into it and carve out my design.
Everything looks good, I send it to gSender and when it cuts out the pocket, the top of the pocket is way too close to the top edge.
So, I checked my piece measurements, (their fine) inputted then into V carve correctly,
But then I ran my machine around the piece in gSender (to confirm the measurements)
and it comes up not correct with my original measurement.
I’ve calibrated, everything is fine. Not sure what is going on here.
Any ideas?
@RicP Can you post your .crv file?
sorry for the late response…
can’t load file , say it’s too large. (over 4mb)
loaded a photo
the entire material dimensions (from Vcarve PRO)
(X) 614mm x (Y)609mm
BUT
when I measure it with my machine (gSender - putting 6mm endmill snugged up to each edge)
gSender reads
(X) 606mm x (Y)609mm
I’ve checked using gSender calibrate, movement tuning and the accuracy is spot on.
at a loss…
added link to the file
Here is a link to the file through my DropBox.
Might be a simple error of the bit cutting on the line, above or below the line. whne you set you tool path up it offer these options.
@RicP When you measure the rectangle with a tape, what are its measurements?
Do you mean in V carve?
563.7mm (x)
559 mm. (y)
@RicP No. I mean take a tape measure and measure the rectangle. I assume that you’ve already done that with the material.
It would be best to see the .crv file. If you have Dropbox, you can upload it there and post the link here.
I did upload the file from Dropbox
It’s above
Just measured the profile on the material,
It measures
563mm X
552mm Y
The Vcarve dimensions are different on the drawing.
*see vcarve dimensions above
@RicP I’ve just opened your file. In your first post, you said that your material size is 614 x615. In your file, the material size you entered is 614x609. In your latest post, you say that your profile is 563 x 552. I assume that is rectangle that you measured with a good tape, yes?
The rectangle in you file measures 563.95 x 559.206.
With respect, your measurements are all over the map.
Since you are setting your XY0 at the left front corner, your rectangle will not be centred on the actual material if you have entered a material size that is not the actual size of the material. VCarve will show it centred because it assumes that you have entered the correct material size.
You need to either set the material size to the correct size or set your XY0 to the centre of the material.
I totally understand,
Let me explain, regarding the measurements, the first post 614 x 625 was a hypothetical number I was using to reference a rectangle, I was really trying to convey more that I was wanting to put a 20mm boarder around the piece. Which I did later change to 25mm on the design. ( that’s on me, I didn’t expect that someone would want the actual measurements of the piece, lesson learned. )
In the post above, the one I ask if you want the measurements from Vcarve… I posted the file measurements, that you just confirmed.
563.7mm
559mm
The post where I actual measured the physical material profile, the measurement was 563mm x 552mm and not centered.
This is the issue I’m having, the discrepancy between the software measurements and the machines actual cuts and centering.
Honestly, I don’t think my measurements are that much off.
I’ve had my CNC for around a year and cut several projects without an issue, the project I just finished before this one was a similar piece of MDF ( approximately same measurements ) with a different design and everything cut without incident. I’ll try and set my zero in the centre and see if that fixes it. Thanks for your help and patience.
@RicP Understood. To be clear, I was not saying that the only way to achieve your objective is to set XY0 in the centre. Doing that, then running a profile/cutout pass at the end of the project will ensure that your project details are centred on the final material.
Doing that also reduces issues with the actual starting dimensions of the material not being spot on.
If you prefer to set XY0 on a corner, using the touchplate, for example, and if your final toolpath will not be a profile toolpath that cuts through the material, it is critical that your actual material dimensions and those that you enter into VCarve are the same. If your final toolpath is a profile through cut, and depending somewhat on your project, it really is not critical, as your final piece will be centred in the cutout material.
Clear as mud?? :grinning:
:sunglasses::+1:
Totally understood that… and understand that your advice is a step forward in the process, which I’m grateful for.
Still trying to figure out why the material dimensions in V carve change when outputting to gSender.
I’m starting to suspect it may be a touch plate issue.
I really appreciate your time and patience in this matter. If I come across an obvious solution, be it software or operator error, I’ll post it here.
Thanks again.
@RicP Quick question. What post processor are you using in VCarve?
As Promised… I found out what the problem was from a tech at Sienci.
In the firmware settings the stepper motors travel resolution (default 200 on XYZ) were off, he seems to think this may have occurred during an XY squaring operation, seeing I’ve never tampered with anything in this area. As of now, the machine seems to be working true.
