MK2 CLSM Upgrade
Just received my new CLSM kit and was eager to install it right away. The setup went smooth except for when i opened up gSender to move things for the first time..
When trying to jog in any direction i just hear a click and then silence, no movement at all. No indications are present on the controller that show any issues. CNC status light is white and the rest are green. Each stepper motor has a green light indicator as well.
I do receive an Alarm 10 when connecting, but my estop is definitely not pressed…
Buttons work on the eStop for a flood command.
Inductive sensors work when triggered.
I’ve confirmed the new motor settings and used the CLSM macro, downloaded new v1.5.6, and uploaded firmware settings from my previous setup with the SLB
Any ideas? I’ve reached out to tech support, but was wondering if anyone has had a similar issue?
@RasterTheGrain Why did you change the firmware settings on the new SLB-ext to those from the SLB? I don’t know if they should be different, but, in my ignorance, it would seem to be that it may not be recommended to change the firmware settings that the SLB-ext came with to those from a different controller.
Thanks Grant
I was grasping at straws at that point. But I did just do a factory reset and it seems to work fine now!
