Need some info. I have started having ESD issues causing the usual stopping, alarms etc. I know cutting MDF doesn’t help. I want to ground as much as I can on the LongMill as well as the dust collection system. Was wondering what the AWG wire size is for the motors as I want to switch to shielded cables. I will also be grounding as many of the metal parts that I can that are not connected electrically. Directly to a ground rod not the power panel. TIA
@Heyward43 H. Mine say 22awg on the insulation.
edit: PM sent, H.
Thanks Grant. I never thought to look at the wires.
