My latest cribbage boards
These are an upgrade to my original design. I’m using larger magnets and have added the skunk marker between 3rd and 4th streets.
The left one is oak with purple heart inlay and the right is maple with purple heart inlay. The skunk is not part of the inlay. The inlay went around the perimeter of the skunk so I could get the lighter colors in the stripes. The skunk and line work is done with a laser and everything but the finish work was done with my LongMill 30x30.
Both upgrades were in response to constructive criticism from a customer. So far everyone seems to really like the addition of the skunk.
Thanks for looking at my work. Have fun and be safe!
That looks fantastic! Any key tidbits or learnings in your inlay process?
Beautiful work @_Michael ! I love the inlay and especially the :skunk: marker. Adds a bit of humor to the great game of cribbage. My dad LOVED cribbage!
TLDR; Copy settings from pictures, win!
These are my settings for the cribbage board inlays along with part of this other post. Use the top link if you want further reading because there is a description and procedure file that’s a good read there.
Okay so what do these settings mean you ask?
Well let’s start with the pocket or female part. It’s just a plain old v-carve and all you need to decide is how deep you want to go into the receiving part. I chose 4mm and might be able to go thinner because I think I’m getting an inlay without a gap at the bottom.
As you can see for the plug or male part on the right we have a start depth of 3.75mm. The start depth represents the vertical distance from the bottom of the male part to the top of the female part i.e. the overlap. If we subtract that 3.75 from the 4 we have in the pocket that leaves 0.25mm gap at the floor of the pocket. The flat depth is set at 2.25mm and it represents the gap between the male and female parts that you can run your band saw blade in to separate them.
On the machine the thing that will bite you is the start depth of the male carve. If you run the generated tool path it’s going to start 3.75mm into the surface PLUS whatever it’s pass depth is calculated to be. I have been running the male carve three times. Starting with the surface set 4mm high (0 at 4mm off the surface for most people), 2mm high, then the normal one. Without doing something to compensate it’s just taking off too much meat for me.
I’m using a 45° v-bit because it’s the steepest one I have besides small engraving bits. The steeper sides should be more forgiving if you have to sand/plane off a little more or less. As you travel away from the surface of the female the inlay expands or shrinks. You can see it on one of the boards, a little white perimeter around the skunk. That would have been wider had I used a 90° bit.
With only a 0.25mm gap set between the parts and the four clamps I’m pretty sure the bottom is mated. That should let me do a shallower pocket without breaking the inlay, at least that’s my theory. With my current settings I started with 20mm or a fat 3/4" purple heart and after the two inlays I have 6mm or a skinny 1/4" left. I think that last piece can do another because I won’t need the 2.25mm saw blade gap, I’ll use 0.5 - 0.75mm and the rest of the 2.25 would hold it together.
Something to consider if your doing two sided inlay work is you have to make sure you can accurately get back to the inlay side to clean up after the band saw or add more detail.
Use some MDF or something to sandwich your inlay to distribute the pressure and protect your work.
Don’t rush the dry time on the glue, you’ve wasted at least the inlay wood if it moves on the band saw.
If you get a bad inlay and you can accurately get back to the inlay, you can run the v-carve for the pocket again and maybe save the female part.
I run the clearance pass first, not sure if it matters… … …remember to flip the male design… … …
Excellent!! Love the little skunk! Very nice touch. Is that another inlay?
Is the purple heart inlay one piece or multiple pieces? I’m so new to the cnc world and considering ordering the new Altmill but the shipping date is soooo far out, 5-6 months.
The purple heart is all one inlay. It is very skinny at the top and bottom of the skunk but it’s all one piece, leaving the original wood for the laser to make the skunk on.
Yeah, that’s awhile to have to wait, but it does look like a beast of a machine, very fast in the videos I’ve seen.
Nice work and great feedback with follow up. The resources really help us newbies to at least get motivated.
@_Michael Well wouldn’t you know it, I was asked to do something I’d never thought I’d do…a cribbage board. I might have to steal this design. Any changes you’d make since this one?
My first board with this basic design had a lip where the two halves joined. The perimeter wall was basically divided in two, with a small gap, so that you couldn’t see through from side to side if the fit wasn’t perfect. I think I would put that back in.
I took it out because with the lip there was only space for very small magnets. These magnets, 6x3 mm I think, held much more firmly but a couple didn’t press in flush so there was a small gap where you could see light from the other side. I guess your better off going a touch deep on magnet holes? Mine fit tight so there really wasn’t a way to test fit before gluing them in. I used a clamp to try and get them flush but then I was afraid of breaking the whole thing if I went too crazy!
I was limited by the size of my stock. The sides had about 1mm milled off the edge so I would have needed to adjust the inlay and holes to keep the lip. I decided to just lose the lip rather than take the time.
Funny thing is, the board that had the lip is my only Etsy return, not that have a lot of sales. It’s also my only review, 4 or 5 stars for a returned item. :zany_face: They didn’t think the magnets were strong enough and the small gap between the lip and bottom wasn’t perfectly the same distance all the way around.
On a side note, the return was from coast to coast in the USA and the buyer had to pay return shipping. If that situation comes up again I think I would offer to return part of the payment and let them keep the item. It seems like Etsy and the shipping company were the only ones to profit from this ‘sale’. I felt bad for the buyer because it was all loss for them.
EDIT: Here’s a tip if you have to drill through an inlay. Try not to have a big gap at the bottom because it makes a real mess if there is soft glue under the inlay when your milling all those holes. Also chips will get in between the layers and it will take forever to blow them all out. Live, learn, die! Forget?
Good to know. Might be a job for my favorite adhesive…epoxy
Thanks for the confirmation Sarah. My wife tells me that I can be very convincing. But most of the time, she tells me I’m full of it. How can I respond to that? Tell me, do you, Santimirova, and Nicholas all work for the same employer? If so, sounds like a great tron-like place to work.
@sarahrobinson No offence intended, Sarah, but can you tell me please which AI engine you are using to compose your posts?
Hey @Chucky_ott & @gwilki,
Sarah can’t come to the phone right now, she’s actually moved out. Along with about 15 other friends. I don’t think they will be missed.
Cheers,
Stephen
@StephenCampbell @Chucky_ott Damn! I was so looking forward to a scintillating conversation. :grinning_face:
