My T1 Autospin not working on S-mode
I had installed Auto Spin T1, last week with some success on being able to start the Spindle in TEST mode by pressing on the Forward button and changing the speed and then pressing on Stop.
And now my Auto Spin T1 will not turn on automatically on the S mode. The spindle does work in manual mode for the other speeds
I redid the Setup AutoSpin in the configuration panel in Gsender. I followed the instruction, closed my SLB and then turned it back on. I rebooted my laptop, I reset my firmware in Gsender, I redid the AutoSpin setup a couple of times. And still does not work!!!
Any ideas would be appreciated
@Allan Have you confirmed that you have the spindle selected in your eeprom settings and the you are in spindle mode in gSender?
When you say eeprom settings, are referring to the config in Gsender. If so yes on both accounts
To make sure we are on the same page (tihi), you are using this here instructions?
Hey Eddie, I don’t quite understand your answer. It does not seem to correspond with my top question on why doesn’t my new T1 auto spindle work on the S-mode
Ney Allan,
I did not answer, zi asked if the linked page is the instruction you are using.
I have no autospin and can’t be of much help, but like to learn about this tool and it’s quirks so I browsed the autospin online manual a wee. Since you mentioned instructions, I was wondering what instructions you use, for there seem to be multiple options.
Are both lights on the top of the AutoSpin lite up? I got one and it has worked with gSender 1.5.7
Hey Lewis
Yes both lights were on, but I found the problem. After emailing back and forth with customer service at Sienci Labs, they asked me to check the polarity of the connector. There was one the wires that was loose which was not giving a good contact. Therefore it was not allowing the Autospin to work on the S-mode
Good to know. If at some point mine starts to act up I’ll know what to check.
