My Y- travel buttons seems to be working opposite
I just finished making two macros after setting up my tool length sensor , the machine was sitting idle for a half hour then I pressed the Y- control button and it went in the opposite direction which gave me an alarm 10.
after that the Y- moves moves the gantry to the Y+ direction and alarm 10 again as its so close to the home position
I tried inverting the Y direction but that makes no difference
also if I press the arrow button between the X+ and Y-, the movement is only in the X+ direction. wonder if a driver blew ?
Got it back working correctly again, found that the Y axis maximim travel had dissapeared , likely after I created a G28 macro, even after deleting the macro.
I hit the default button and applied the setting change. Dont know if thats a bug in 1.5.7
anyway its all working now
