I’ve been using my machine for a couple months now and trying to solve some problems I’ve run in to. I have the larger long mill and I use the vcarve and gsender programs.
The problem I have is sometimes the machine will not cut evenly.
For example: tonight I was using the pocket hole to cute out some baseball stitches . The first three stitches cut out fine but the other one did not cut as deep. The first few passes didn’t even carve into the wood.
Any tips on how to fix this? I’ve looked but can’t seem to find anything online that matches my question.
Thanks!!!
Is your spoil board surfaced correctly? If one part or side of the table is farther away this can happen as well. I just recently noticed that my spoil board needs to be surfaced again. It was perfect but we have had a lot of humid weather and I think it threw my table and spoil board off.
@Addison While it’s likely that the mechanical things that @elbarsal and @_Michael mentioned are the cause of your problem, if you post your .crv file, it may show something going on there.
trying to upload the crv file, it is telling me new users can’t upload the file.
We just checked out the machine and everything was tight and ran well.
I’m thinking it could be the file. I just discovered I could edit the tool paths instead of making new one.
Could it be that I have too many tool paths on the file even if I am only saving one?
