Howdy folks,
Just finished assembling my new hobby… I’m curious if there’s any recommendation on whether or not I should lubricate the lead screw with a thin layer of grease or something? Trying to make sure I take the best care of this thing!
I am anal about lube on the lead screws. Its probably not needed, but I use the WD40 Dry lube on the lead screws. It may not help, but I dont see that it hurts.
The last thing you want to do is put something sticky on the lead screws. It will collect everything and keep it right there, making it more likely the bits and pieces will make it into the inner works.
A light oil that is applied a drop on each side, running the axis back and forth, then wiping the axis down afterwards to remove any excess oil that may provide a surface to collect the bits.
Dry lube, usually graphite-based, will start putting the dry lubricant inside the delrin, which isn’t too good.
