New user considering Vectric Pro software
I am on the Vectric site considering buying the pro version. in the free trial area it says there is no limit on how long i can try. is it based on the amount of projects i can do . if there is not limit why would i buy it?
Try before you buyTry out all the design features to check the software is right for you before you buy
Test machine compatibilityDownload one of our free trial compatible projects to test compatibility with your machine set-up
No time limitsThere are no time limits to how long you can test the software for before you buy
@fonthillhd Keep reading. You would buy it because you can’t cut any of the projects that you make. There are a couple of test files that Vectric provides that you can take to completion. However, anything you design, you can save, but cannot cut. Also, if you do decide to buy it, you must save it to the same computer where you saved your “trial” files, or you will not be able to cut them either.
