NymoLabs Wireless touch probe delay
After installing and connecting NymoLabs probe Im getting ERROR:
Probe fail. Probe is not in the expected initial state before starting probe cycle when G38.2
and G38.3 is not triggered and G38.4 and G38.5 is triggered.
Input: N/A
Controller: Grbl
There is no ERROR if I manually run G38.2 Z-50 F15 it triggered properly and Heigh set as it should.
Dont know why Z-probe triggers alarm with ERROR 4 and ERROR 9
Grbl for ARM32
Version:ARM32 V3.0
$0=10 (step pulse,usec)
$1=255 (step idle delay,msec)
$2=0 (stepport invert mask)
$3=3 (dirport invert mask)
$4=0 (stepenable invert,bool)
$5=1 (lims pin invert,bool)
$6=1 (probe pin invert,bool)
$10=3 (status report mask)
$11=0.010 (junction deviation)
$12=0.002 (arc tolerance,mm)
$13=0 (report inches,bool)
$20=0 (soft limits,bool)
$21=1 (hard limits,bool)
$22=1 (home cycle,bool)
$23=3 (homing dir invert mask)
$24=100.000 (homing feed,mm/min)
$25=500.000 (homing seek,mm/min)
$26=250 (homing debounce,msec)
$27=1.000 (homing pull-off,mm)
$30=31250 (maximum spindle speed,rpm)
$31=1 (minimum spindle speed,rpm)
$32=0 (laser mode enable,bool)
$100=800.000 (X axis pulse:step/mm)
$101=800.000 (Y axis pulse:step/mm)
$102=800.000 (Z axis pulse:step/mm)
$103=177.777 (A axis pulse:step/mm)
$110=4000.000 (X axis max rata:mm/min)
$111=4000.000 (Y axis max rata:mm/min)
$112=4000.000 (Z axis max rata:mm/min)
$113=1000.000 (A axis max rata:mm/min)
$120=500.000 (X axis acceleration:mm/s^2)
$121=500.000 (Y axis acceleration:mm/s^2)
$122=500.000 (Z axis acceleration:mm/s^2)
$123=20.000 (A axis acceleration:mm/s^2)
$130=300.000 (X aixs max travel:mm)
$131=300.000 (Y aixs max travel:mm)
$132=80.000 (Z aixs max travel:mm)
$133=9999.000 (A aixs max travel:mm)
G10 L20 P0 Z0
ok
G91 G21
ok
G38.2 Z-30 F150
[PRB:0.000,0.000,-3.368,0.000:1]
ok
G91 G0 Z2
ok
G38.2 Z-3 F75
ALARM:4 (Probe fail)
ok
G4 P0.15
error:9 (G-code lock)
G10 L20 P0 Z38.28
G91 G0 Z2
G90
[MSG:Caution: Unlocked]
ok
$J=G21 G91 Z1 F1000
ok
$J=G21 G91 Z1 F1000
G10 L20 P0 Z0
G91 G21
G38.2 Z-50 F150
G91 G0 Z3
G4 P1
G38.2 Z-3 F15
G4 P0.15
G10 L20 P0 Z38.28
G91 G0 Z2
G90
Adding a wait command between 2 probes solves the issue.
Is it possible to add a wait for the probe settings?
Ah, this must be because the wireless probe takes much longer to send and receive signals to the board, meaning that there needs to be a longer delay between probes to ensure that the firmware doesn’t think it’s in the incorrect state. I’ll see what we can do. How long of a wait did you need to add before the probing worked?
I’ve seen the other app has implemented a extra field in settings to add a waiting time between the probes.
In my case 100ms was enough, but hard coding not really great solution.
That’s odd because currently our default delay is 150ms, so I would expect it to work if in other senders you’ve used 100ms. Are you sure that the value is correct?
You are right. In the code I posted earlier.
G4 P1(Dwell for 1 second. )
So delay is 1sec.
@pioneerko So, your delay is 1000 ms, not 100?
My delay is G4 P1.
Which translates to 1second = 1000ms.
@pioneerko Yes, that’s what I understood. I was thrown off by your previous mention of 100 ms and Chris saying that the default is 150ms.
My bad. Mistyped 100ms instead of 1000ms
Same thing just happened to me, thanks for the GCODE above, I just jammed that into a macro for the time being to get probing working. I also looked up all the codes and commented them to learn better. Thanks!
G10 L20 P0 Z0     ; setup initial state at zero
G91 G21           ; relative positioning, move in mm's
G38.2 Z-50 F150   ; move, at most, 50mm down in z at 150mm/s
                  ; until probe goes off
G91 G0 Z3         ; go up 3mm
G4 P1             ; pause for 1 second
G38.2 Z-4 F15     ; find zero again, (max 4mm down, move slowly
                  ; for very accurate position, wireless is
                  ; slower than wire probe)
G4 P0.15          ; pause for 0.15 seconds
G10 L20 P0 Z38.5  ; set z based on current position, but down
                  ; Z amount (38.5) -- the height of your probe
G91 G0 Z2         ; go up 2mm to get off the probe
G90               ; go back to absolute positioning
