Building a linux-x64 image works fine and it runs without this error output on this Intel machine here.
Building a linux-arm64 image does not work on my Odroid N2. The command was:
npm install && npm run build-latest && npm run build:linux-arm64
I ran this command from another local machine in my network but I get the same output if I run it directly on the Odroid N2.
mcguirk$ DISPLAY=:0 ~/bin/gSender-1.0.7-latest-arm64.AppImage
MESA-LOADER: failed to retrieve device information
MESA-LOADER: failed to open zink: /usr/lib/dri/zink_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/dri, suffix _dri)
failed to load driver: zink
MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/dri, suffix _dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/dri, suffix _dri)
failed to load swrast driver
04:02:09.247 › Error: /tmp/.mount_gSendeszbIuu/resources/app/node_modules/@serialport/bindings/build/Release/bindings.node: cannot open shared object file: No such file or directory
at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1812)
at Object.Module._extensions..node (node:internal/modules/cjs/loader:1199:18)
at Object.func [as .node] (node:electron/js2c/asar_bundle:5:1812)
at Module.load (node:internal/modules/cjs/loader:988:32)
at Module._load (node:internal/modules/cjs/loader:829:12)
at Function.c._load (node:electron/js2c/asar_bundle:5:13343)
at Module.require (node:internal/modules/cjs/loader:1012:19)
at require (node:internal/modules/cjs/helpers:102:18)
at bindings (/tmp/.mount_gSendeszbIuu/resources/app/node_modules/bindings/bindings.js:112:48)
at Object.<anonymous> (/tmp/.mount_gSendeszbIuu/resources/app/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1116:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
(node:8256) UnhandledPromiseRejectionWarning: TypeError: Message must be a string
at messageBox (node:electron/js2c/browser_init:49:3930)
at Object.showMessageBox (node:electron/js2c/browser_init:49:5487)
at _callee4$ (/tmp/.mount_gSendeszbIuu/resources/app/main.js:353:37)
at tryCatch (/tmp/.mount_gSendeszbIuu/resources/app/node_modules/regenerator-runtime/runtime.js:63:40)
at Generator.invoke [as _invoke] (/tmp/.mount_gSendeszbIuu/resources/app/node_modules/regenerator-runtime/runtime.js:294:22)
at Generator.throw (/tmp/.mount_gSendeszbIuu/resources/app/node_modules/regenerator-runtime/runtime.js:119:21)
at asyncGeneratorStep (/tmp/.mount_gSendeszbIuu/resources/app/main.js:53:103)
at _throw (/tmp/.mount_gSendeszbIuu/resources/app/main.js:55:291)
(Use `gsender --trace-warnings ...` to show where the warning was created)
(node:8256) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 3)
mcguirk$ ls -l /tmp/.mount_gSendeszbIuu/resources/app/node_modules/@serialport/bindings/build/Release/bindings.node
-rwxr-xr-x 1 root root 76600 May 14 02:57 /tmp/.mount_gSendeszbIuu/resources/app/node_modules/@serialport/bindings/build/Release/bindings.node
Note that the bindings.node file exists in that /tmp subdirectory. I put the AppImage process in the background with ctrl-Z and ran ls.
Any help will be greatly appreciated. I have just elementary experience with nodeJS and I’m in over my head here.
Thanks!
