Hey everyone. Fairly new longmill owner here. Have done a few successful projects using Easel so far.
I have access to an older version of Vcarve. (v10.?) I have made a couple of projects. Nothing too complicated, just a simple relief Vcarve. Problem is, the gcode I export has a lot of errors in Gsender. When I run the job I get a few stoppages. Weird thing is, when I run the job again, sometimes I get no errors at all. It is not at all consistent. I know nothing about gcode files, granted, but wouldn’t the job fail at exactly the same line every time? Could it have something to do with the older version of vcarve?
I am just looking for a place to start looking for the problem. Is it possible it is not the gcode file at all? my longmill seems to run perfectly fine when using Easel though, for example.
Appreciate any advice you guys and gals can offer!
I will try your suggestion when I get back in the shop. I did take note of one of the error codes I am getting. “error 1 expected command letter grbl”
I get that same error for several lines of gcode. Not quite sure what could be causing it. Must be a setting in Vcarve somewhere, but I have no clue how to fix it.
@LargeFry You may want to post the gcode file that is throwing the errors. There are members here that are quite expert at reading gcode and sussing out errors. (I’m not one of them.)
