Outline gives soft limit alarm if Z is withing 5mm of top
If outline is started when the Z axis is within 5mm of the top of travel you get a soft limit alarm. Moving down the Z axis 5 mm it works ok. This is a bit of a pain because after homing if you check the outline it fails .
Hi @MtrDLP I just checked this again in 1.5.3 and it still seems to be here, so we’ll look into fixing it
To respond back here, 1.5.4 should now have this issue resolved. Let us know if it’s OK for you now @MtrDLP !
Super! Thank you. :slightly_smiling_face:
