What is the overall height of the long mill, with z axis at its highest point?
About 14โณ. But if youโre planning to build an enclosure you should make it at least 20โณ tall to ensure enough space for hose management, manipulating cutting material, etc.
Ok, great, thanks for the info!
And if you donโt put the router at the lowest point in the bracket, the top of the router can be near the top of the height limit so that pushes your cable issue higher.
-Jeff
