I’m using Longmill MK1 with Gsender. I’ve got a pocket carve coming up that is 330 minutes. There is lots of little corners that requires the use of a small bit (1/32). I’ve got four of these to do, ties up a lot of hours just for that part of the project.
I’m wondering if there is a way i can stop/pause that carve one day and continue on another?
I use the start from line function in gsender regularly. When I stop in the middle of a job I note down the start from line then completely shut down the following day I restart, re-zero, load file a nd use start from line function. I always start a few lines previous to the stop line. The process is described in the gsender documents on sienci main site.
